Re: 64 SB oil pan plug
Joe-----
I do not know very much about this. I always thought that NO Corvette at least through the C4 era was ever originally equipped with a magnetic plug. Now, I'm not so sure. Here's why.
The 1966 edition of the P&A Catalog says this:
65-66 PASS., CORVETTE w/Sp. H/Per.(396, 427)
66 CORVETTE (427) (exc. Sp. H/Per.).......
SCREW(Magnetic) (1/2-20 X 1-5/64).....3866916
ALL, CORVETTE w/magnetic drain plug.......PLUG (1/2"-20)..........3866776
The first catalog listing is highly contradictory. However, it would seem that at least some 65-66 big blocks were to have used a magnetic drain plug in PRODUCTION. This kind of listing does not look like a SERVICE-only or accessory part type listing.
The second listing MIGHT indicate a SERVICE-only application but the "w/magnetic drain plug" implies that some other applications might have originally used it.
The 1967 P&A Catalog basically says the same thing as above except it curiously adds "F.I." after "w/Sp. Hi. Per." but still follows that with "(396, 427)".
The thing that I am most curious about, though, is what's the difference between a GM #3866916 and a GM #3866776? It turns out that the 3866916 was discontinued in January, 1970 and replaced by the 3866776. GM #3866776 was then discontinued in November, 1976 and replaced by GM #337185. GM #337185 was discontinued in March, 1986 and replaced by GM #23011420. The 337185 and 23011420 have 9/16" across-the-flats (wrench size).
But, what's the difference between a GM #3866916 and a GM #3866776? That's what interests me. They both cost $1.00 in 1966.
Joe-----
