Re: C2-3 differential backlash
I think the 50-70 ft. lbs spec is WITH the posi springs installed. There should be very little clutch drag without the springs.
Also, from LOTS of experience, I learned in the mid/late 60's that if you set the differential pinion gear rotational backlash at specs, especially the tight end of specs, the positraction will almost always chatter on corners, no matter how many of those little bottles of additive you add.
If I remember correctly, the GM manual called for a rotational clearance of something like .003"? I would shoot for a bit more clearance.
Torque input is what makes the positraction clutches function. The small pinion gears force the side gear into the clutch packs under acceleration. The harder you accelerate, the more force is applied.
The spring pack with plates is also used to load the side gear and clutches so the positraction functions when only a light throttle/load is applied, such as when one wheel is on snow/ice.
