59 Windshield Replacement - NCRS Discussion Boards
  • John C.
    • September 30, 2001
    • 130
    Two questions, I want to order a tinted windshield,any throughs,and what else do I need to complete the job?
    Thank You
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 59 Windshield Replacement
    Not sure about the tinted windshield but if you check the archives I believe there were some really good threads about installing a C1 windshield.
    • Richard T.
      • February 1, 1979
      • 858
      Check the ST-12, it has a good description of the job as well as some pictures. What you will need depends on your car , most likely you will need the main windshield weatherstrip which surrounds the glass in the frame, the rubber filler strip that goes in the upper channel, rubber shims that go under the windshield posts and so on. If the tabs on the posts are broken they will need repair, maybe re chrome, stainless may need polishing, a hardware kit. Buy a good quality glass so it fits the frame. Some cheaper ones don't. Good luck Rich
