72 LS5 TCS wiring question - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5134
    I'm assuming that a 72 LS5 (4-speed, with air, if that makes any difference) does not use a TCS relay behind the tach. AIM LS5 p. A10 shows a "jumper strip" (view A) in that location. Am I reading that correctly? And exactly what is a 8905858 jumper strip?
    Thanks!
  • Bill C.
    • July 15, 2007
    • 904
    Re: 72 LS5 TCS wiring question
    Correct - does not use a relay.
    The jumper is 2 prong and fits into the connector for the relay.
    It is the two outer prongs (pretty sure).
    • Mike E.
      • February 28, 1975
      • 5134
      Am I correct in assuming, although it looks like a more modern fuse, that it is not, and instead simply effects an electrical connection between the two wires it connects?
      • Bill C.
        • July 15, 2007
        • 904
        Mike,
        I am not 100% sure.
        It does not seem like it is a "fused link" type of jumper to me.
        I am pretty sure you could just jumper the connect with wire and it would work just fine.
        Hopefully someone with more technical knowledge will chome in on this ..
        • William C.
          • May 31, 1975
          • 6037
          Mike that part is (was) just a shorting clip, the service manual wiring diagram doesn't really show enough detail to see exactly how it is used, it was onluyused on the LS5, per the service manual, looks like used in place of the TCS delay relay? Think of a stamped brass bar with an insulating coating in the center.
          Bill Clupper #618
