Main harness to steering column - NCRS Discussion Boards
  • Tom R.
    • April 7, 2008
    • 135
    Can somebody give me the password for disconnecting the main dash wiring harness from the connector on the steering column? It's the white plastic connector not the thin black one. It simply will not let go. Are there tabs on the connector that I'm not seeing or do I simply need to be a bit more aggressive?
  • Jamie F.
    • May 20, 2008
    • 337
    Re: Main harness to steering column
    Yes Tom, there is a tab on the bottom (standard column) or on the top (tilt & Tele) that you need to depress to pull the connector out. As you probably found out it cannot be removed until the black one is first removed.
    • Tom R.
      • April 7, 2008
      • 135
      Tilt-Tele - and with tab as you pointed out it popped right out
      Thanks Jamie
