I have a 1967 327/300 HP convertible. I had the valve cover off the driver's side today and took some pics. Car was built April 18th. Here is what I found:
Time Clock 1:00
GM
5
T
3890462
L275
From reading it seems to be the correct head (3890462) that was used in 1966 through May of 1967. I assume the "T" stands for Tonawanda. The date stamp confuses me a bit as one book states Tonawanda heads always used a two digit year date in the date codes. That would make it December 2nd, 1975 (?) or is it December 27th 1965, which frankly doesn't make sense either? Thanks.
Kirk
Time Clock 1:00
GM
5
T
3890462
L275
Kirk
Up to this point the car has seemed pretty original, wonder what happened with the heads? Anyone got a used pair of early 1967 or late 1966 462 heads sitting around?
