Carter ID - NCRS Discussion Boards
Carter ID
  • Garry B.
    • January 1, 1991
    • 660
    Carter ID
    Can someone help me identify the following Carter WCFB: airhorn 6-1396 and body 0-1241.
    Thanks.
    Garry 18531
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
    Re: Carter ID
    The primary Carter components (air horn, body, base) were used on different specific Carter models that served different car mfgr applications. Often, when these carbs went though the hands of a rebuilder, various pieces were 'shuffled' to create a functional/working carb that served a particular purpose. It was the ID tag that provided the original target Carter model number, but these were frequently discarded...
    In your case, the 6-1396 air horn WAS used in Corvette applications. It was factory installed on 2818S carbs employed in 1958-60E. And, it was used on 3059S carbs for the 1960L-61 model years.
    The 0-1241 body isn't recognized as being a 'Corvette' piece...
    • Garry B.
      • January 1, 1991
      • 660
      Re: Carter ID
      Thanks Jack. I knew that the airhorn was correct for corvette, but the body was stumping me. As you suggested, someone must have used parts from different WCBF's to get to a working carb.
      Garry 18531
      Garry Barnes #18531
