I have a question regarding the correct thermostat for a 75 L48 coupe. I believe that the correct stat is rated at 195 degrees with an air pump. My car has a long disconnected air pump. Other 75's without the pump can use a 180 degree stat. In the archives, someone stated that the fan clutch was calibrated for the 195 degree stat in 75.
Which one should I use? I have not removed the old stat, since it is currently working ok. Next flush and fill will be a good time to replace it, and I want to install the proper stat. Which brand is best and reliable?
Thanks for any help
Thanks for any help
