55 Splash Shieds - NCRS Discussion Boards
55 Splash Shieds
  • Robert J.
    • September 30, 2004
    • 117
    55 Splash Shieds
    I need a set of splash shields for my early 55. While looking at the 55 shields at Corvette Central I noticed that they are different from the 54's.
    ? is did they change over at the start of 55 production or like so many other parts on the car, later in the production run...I need some made prior to 1-8-55 .Thanks Bob
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 Splash Shieds
    Good question and I don't have that answer but would think they were changed in 55 because of the right side 12V battery causing the inner fender to change also.
    • Mike M.
      • May 31, 1974
      • 8365
      the DRIVERS side splash shield is unique to the 53-55 models in that they have a rolled "gusset" that runs front to rear on the outside edge of the splash shield.gary moritmer, who repos the 56-62 splash shields, hasn't ever made any for the 53-55 because of the rolled area i mentioned above. the Pass side on our 55 v8 splash sield was easy to repo as there are no rolled areas.it is very close, if not identical to the 56-7 shields. i made a new one for the pass side on our 55 and repaired the original drivers side to retain the rolled gusset. i believe there is still a template for the pass side laying in the shop somewhere . you can have it . if you have a sheet metal brake or access to one, repoping the pass side is a snap. mike
      • Robert J.
        • 117
        Roy, Mike: Thank you so much for your help. I'll just buy the 55 set from Corvette Central and keep an eye out for an original set. I've seen a few go bye on Ebay.......... Thanks again Bob
