I'm in process of establishing how many body mount shims I need on my 63 and I'm a bit perplexed on the #4 mount location behind the rear wheels. The AIM shows usage of the same type of shims used at the other mount locations, but I seem to have almost a 1/2" gap at the #4 mount. This is more gap than I would expect to fill using a stack-up of 1/16" shims.
I'm looking for some input from others 63 owners regarding the #4 mount shim stack on their cars. This mount is easy to view from the rear wheel well.
My car was built on July 24, 1963 (203xx) during the last few weeks of production. Is it possible that the new 64 floor pan configuration had already made it's way into production and a thicker spacer was used at this location until the rubber spacer change came into play with the 64 body mounts?
thanks for the help,
tc
tc
