The previous owner of my 1966 427 425 had the engine rebuilt and a hydraulic cam put in so he would not have to adjust the valves. I want to put the original style mechanical cam back in and want any tips as to the best part numbers, do I replace the rocker arms, the springs, pushrods, etc. Also what is best to remove for access, such as the grille and do I have to lift the motor. I also need help on getting the correct grooved or drilled rear cam bearing for correct oiling. Some posts suggest taking it to a machine shop. I have read the archived posts, but would really appreciate the best part numbers and pitfalls such as the correct oiling groove or bearing and the best breakin oil and proceedure. The archives were helpful, but some members advise conflicted with others.
Thanks for your help, Jerry Nutt
