Well,I'm getting down to the assembly, and I figured I'd start with the throttle body and point out a few differences between original and reproduction parts.
Here's my assembly setup:
Geez, have I got enough parts and manuals. The parts on the table are only about half of my cache of Holley parts. It is also very helpful to have an assembled carb sitting in front of you to get the correct orientation of the parts during assembly.
But the primary manual for this assembly of a 67 carb is this tattered 67 Chassis Overhaul Manual:
This manual came with the car when I got it in 68, it was ordered by the original owner from the card in the owners manual. It sat in the jack compartment for many years, as you can probably tell.
However, this 67 Overhaul Manual vs the Service Manual, is the only many that I have found that describes the overhaul procedure particular to the 67 carbs with the non-externally adjustable floats in the fuel bowls. It also has lots of pictures and assembly diagrams of a 67 3810 from which you can tell the original configuration of the carb. Here's on diagram from the Chassis Overhaul Manual:
In preparing for this project I ordered a lot of reproduction parts for parts that I might need. I found that a lot of new reproduction parts are a lot different from the original parts. Here's an example:
If you will notice the three Secondary Throttle Stop screws in the center of the picture, one is a reproduction, one is a screw I made, and one is from an original 65-66 throttle body. On this 67 3810 throttle body I couldn't get the set screw out of the body for the life of me, so I had to drill it out. So I ordered what I thought was a correct replacement.
The replacement came as a #10 X3/8" set screw whereas the original was a #8. ( I guess they figured that once you drill them out, you would retap the hole to a #10).
But the threads were still good on mine, so I made a stop screw from a hardware store slotted set screw (#8 X 3/8") by just deepening the slot and rounding the opposite end. But then I found another vintage base plate with a #8 stop screw which came out easily. So that's the one I used.
(continued next post)
