I live in California and just insulated my 22 X 30 garage. Both walls and ceiling have vapor barriers facing the "warm side" of the insulated space (I now understand that some recommend not using a ceiling vapor barrier because of condensation). The insulation is R-19 and the double and single garage doors are probably R-6.
I have not yet connected the 24000 BTU Split AC/Heating unit so it is unheated space.
There are no vents between the garage space and the attic or outside walls. The attic space is not insulated and has soffit vents and a gable vent.
Lately the outside temps are 35-55F and the garage is staying about 60F all the time.
My problem is when I park a wet car in the garage it will stay wet for days.
Should I install a large bathroom type exhaust fan and exhaust it through a roof vent ? I am concerned that it could cause my water heater pilot light to go out by the air draw.
Would a dehumidifier work better ?
Once I connect the split AC/heating unit would that take care of it ?
) mini-splits using inverter technology. These units have a variable speed compressor and fan motors that deliver cooling in proportion to demand. If there is low demand the compressor and fans slow down this allows the unit to run longer which results in better dehumidification.
