The picture is of three ballast resistors, picture one is a resistor removed from a 1963 340HP car. Picture two was just removed from a AC tractor that was converted to a 12V system prior to my purchase. Number three is a reproduction. Notice the bracket top on resistor one and two, number one has a short flat spot and number two has a longer flat spot. The reproduction is oval with no flat spot. Resistor one and two have a indent on the sides of the resistor, the reproduction is smooth.
What is difference between resistor one and two? What other areas should one look fore when determining the correct resistors?
Thanks for any information!
Ray
Ray
