Looked at a 67 327-350hp car with power steering. The crankshaft pulley had 3 grooves. One was the alternator, second was the power steering and the groove closest to the fan was empty. Just wondering what the third grooive was for, a/c? Happy New Year. Thanks, Joe DeLuca
67 Crankshaft pulley
Re: 67 Crankshaft pulley
It's probably the "captive belt", which only goes around the crankshaft pulley and the water pump pulley. They are a PITA to put on. It's there in case your alternator belt breaks, you will still have a redundant belt to turn the water pump until you can make it to a garage to get fixed.
So when are you picking up the car?
- Top
If the car does not have AC, there should not be a third groove on the crank pulley. The third groove was only installed on cars with AC.
If the crank pulley arrangement uses original GM parts, the third groove is actually a separate, add-on pulley that nests inside the 2-groove crank pulley. So, it is easy to remove.- Top
Joe and Joe------If the car does not have AC, there should not be a third groove on the crank pulley. The third groove was only installed on cars with AC.
That's correct. If the car is an L-79, then the only way it should have had 3 belt tracks on the crankshaft pulley is if it also had C-60 and N-40.
However, if the car is actually base engine car, then it would have 3 tracks if it had N-40 and regardless of other belt driven options. In the case of a base engine car, one of the tracks was used for a captive belt.
As Joe R. stated, all C2 small blocks that had 3 tracks on the crankshaft pullies used a 1 groove pulley sandwiched onto a 2 groove pulley. No 3 groove crank pullies were ever originally used on C2 small blocks or, for that matter, C2 big blocks, either.In Appreciation of John Hinckley- Top
Joe,Looked at a 67 327-350hp car with power steering. The crankshaft pulley had 3 grooves. One was the alternator, second was the power steering and the groove closest to the fan was empty. Just wondering what the third grooive was for, a/c? Happy New Year. Thanks, Joe DeLuca
I've always thought that the 3rd groove of the crankshaft pulley on a 327, closest to the fan, was always for power steering.Jerry Fuccillo
1967 327/300 Convertible since 1968- Top
The owner emailed me this morning and said it was for the a.i.r.??? He said there was bracket on the engine for the a i r when he first bought the car. I thought it would run on the pulley with the alternator? Happy New Year, Joe DeLuca- Top
Joe-----
The owner is mistaken. The air injection reactor pump for all 1967 Corvettes equipped with K-19 was driven from the waterpump pulley set. In no configuration did it involve a belt which also encompassed any crank pulley. So, any 3 groove crankshaft pulley configuration was in no way related to AIR.In Appreciation of John Hinckley- Top
Joe------
The part number on the pulley or pullies would be helpful in figuring this one out.
If the crankshaft pulley set-up is original to the car, it might be very significant. It could be the "clue" that indicates the car is/was actually a 300 hp that's been converted or "passed off" as an L-79.In Appreciation of John Hinckley- Top
Also the presence/absence of a balancer bolt - the 350hp crank snout was drilled/tapped and used the bolt, and the 300hp crank wasn't drilled and used a press-on balancer.Joe------
If the crankshaft pulley set-up is original to the car, it might be very significant. It could be the "clue" that indicates the car is/was actually a 300 hp that's been converted or "passed off" as an L-79.- Top
- Top
My original 67 L-79 with N60 only has two grooves on the crankshaft pulley.- Top
john
Was that for all base engines ? What about if it had C60 and N40 ? Would it have the double pulley and then the add on ?.
The AIM shows a car with C60,N40 and K19 has no less than 5 seperate fan belts !!
thanks- Top
