What is the correct finish for the exhaust manifold bolt spacers used on C-1 Corvettes? These are the thick washers used on the two outer bolts on each end of the manifold. I have seen them in silver cad and also what looked like black phosphate. Want to be sure before I install them. Thanks Rich
C-1 Exhaust Manifold Bolt Spacer Finish
Tags: None
- Top
Re: C-1 Exhaust Manifold Bolt Spacer Finish
Rich -What is the correct finish for the exhaust manifold bolt spacers used on C-1 Corvettes? These are the thick washers used on the two outer bolts on each end of the manifold. I have seen them in silver cad and also what looked like black phosphate. Want to be sure before I install them. Thanks Rich
I've never seen a silver cad spacer - all I've seen are dark phosphated.- Top
It should be painted engine orange along with the manifold so the plating, if any, isn't an issue.What is the correct finish for the exhaust manifold bolt spacers used on C-1 Corvettes? These are the thick washers used on the two outer bolts on each end of the manifold. I have seen them in silver cad and also what looked like black phosphate. Want to be sure before I install them. Thanks Rich- Top
