'61-'62 rear bumper bolt - NCRS Discussion Boards
  • Michael K.
    • January 1, 1991
    • 43
    Can anyone verify the specs on the pointed bolts used in the rear center bumper on a '61 ? There are 2 different lenghts used. I need the lenghths of the threads and of the total length from head to tip. Thanks, Mike
  • Doug F.
    • November 1, 1983
    • 322
    Re: '61-'62 rear bumper bolt
    mike, the bolts on the 62 i'm just finishing up are, of 7/16 " #14 NC threads, 5/8 " head, the short one has a WB1C mark and is 1 1/2 " top of the head to the point, the longer one is a WB and is 1 7/8" top to point.
    • Doug F.
      • November 1, 1983
      • 322
      tried to attach these with the first post , but failed
      • Michael K.
        • January 1, 1991
        • 43
        Doug, thanks. This should be a big help and the pictures are great.
        Thanks again, Mike
          Originally posted by Doug Faber (6923)
          ..the short one has a WB1C mark and is 1 1/2 " top of the head to the point, the longer one is a WB and is 1 7/8" top to point.
          Doug -
          In terms of ID'ing a bolt or specifying what you need from a supplier as a replacement, bolt lengths are expressed from the underside of the head to the tip (shown in many fastener supplier charts as "UHL" - under-head length).
