I just received a new 4 speed shift boot and starting to think about the best way to install. It looks to me, that in addition to taking the console apart, the "T" handle must go as well to get the new boot over the shift lever. Is that correct?
69 shift boot
Re: 69 shift boot
Jim, you are correct, just be careful with the fiber opitic,s. The cross over brace on front of console, the nuts can be a pain to remove use a flexable socket to ease the removel. if you have the vent cables its a pain to un-hook, A/C cars maybe alittle easier. lastly once your ready for the fiber opitics remove the two phillips head screws on the console,instead of unhooking, that way may break the fiber opitics, lift the rear part of console to access the small phillips screws.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 69 shift boot
Terry------
Yes, all you need is a "stubby" phillips head screwdriver or 1/4" drive ratchet with phillips head driver.In Appreciation of John Hinckley- Top
Re: 69 shift boot
If someone can get the lower boot off without first removing the trim plate I'd be TOTALLY FLABBERGASTED!
By the way, for those that are unaware, the lower boot is really the important one. It's the one that seals out the weather and, more importantly, any fumes. The upper boot is pretty much "secondary" and, mostly, ornamental. Any fumes getting by the lower boot will enter the car even if the upper boot actually seals well.In Appreciation of John Hinckley- Top
