Check photos out and see if you can id these parts. The photo with the plates, 1st plate to the left has "AAc" stamp, and middle plate has a circle stamped into it with an open space in the radius at 4:00. Thanks!
Need help ID'ing parts
Re: Need help ID'ing parts
My vote for the first pic middle plate is a seat nut plate under the car.
Second pic, one is a non power steering shock to frame mount and the other bracket goes to the fuel tank strap where the bolt passes through..- Top
Tim beat me to it, but I'll second it. The middle plate on the left is a under floor seat mount nut plate what appears to be from a Midyear. The small bracket in the right photo is a fuel tank strap/carriage bolt bracket.- Top
Guess I need to clear up my post on the plates as far as location in the picture. Thought I put a different photo in the post.
The bracket on the top has the AAc stamp the middle has no stamp or markings of any type and the bottom plate has the "O" with the section missing at 4:00 position.
So far the middle plate is for the seat mounting. What about the other 2 plates?? Both have the markings as noted above.
Thanks for the help!- Top
