went to my 5 gal bucket of intake water outlets looking for a 3837223 for the 62 360 i've got underway and found four. however, all four had significant pitting of their necks, so much so that antifreeze seeps would almost certainly occur. the casting are too thin to set up in a lathe and machine away the pits. i took the best one, glass beaded the hell out of the pits and then applied the following concoction. Kimball Midwest sells an "Ultra Bond Fusion Kit" which consists of i oz of Ultra Bond Fusion adhesive(contains cyanoacrylate ester---super glue) and 1.4 oz of Ultra Bond Fusion powder. simply saturate the pits with the adhesive, then sprinkle the powder over the adhesive. it sets up immediatly. i waited a day to smooth the patch with crocus cloth. no antifreeze on my intakes. mike
resto tip
Re: resto tip
Sounds like my super glue and baking soda method......
Works great for broken plastic parts too. I dab some super glue in the area to be fixed, slowly add some baking soda and see it build up and instantly cure into a strong gusset. I got the idea many years ago when building RC aircraft using the balsa wood stick built method for strengthening frames and wings.
You need to be careful of the fumes it creates and it may also cause smoke from the chemical reaction.
Rich- Top
Re: resto tip
Rich- Top
- Top
Re: resto tip
Sounds like a good product that can be used for many applications.
Where were you able to purchase this product?? Auto parts? Hobby shop??
Lynn- Top
Re: resto tip
I got mine from one of the vendors at Carlisle two years ago. I think I paid $20 for the kit and it has worked on all sorts of repair jobs. I haven't seen the stuff at local parts stores.- Top
