Did 1975 small block standard corvettes come with rear sway bars ? Or was it a special order or maybe a option ?
Sway Bars
Re: Sway Bars
For 1975, a rear sway bar was installed only if FE-7 suspension or the Z-07 performance package was installed on the car. It was not otherwise available.In Appreciation of John Hinckley- Top
Re: Sway Bars
It's not a great idea to add a rear stabilizer bar without compensating for it with a stiffer front bar; if you just add a rear bar, it will increase rear roll stiffness and the tendency for oversteer, particularly at the limit.- Top
Re: Sway Bars
IIRC the '74 FE7 suspension option was basically the same at F-40 from the sixties, which was the same as the '63 Z-06 setup - 15/16" front bar, 550/305 lb/in springs and no rear bar.
FE7 used the same springs, but increased the front bar size to 1 1/8" inch. Too compensate for the greater front roll stiffness due to the larger front bar, which would have increased understeer with no other changes, a rear 7/16" bar was added to rebalance the roll stiffness.
This setup would work okay in a big block, but it would understeer more than a small block due to the greater front end mass.
The F-41 suspension for sixties big blocks used the same springs with the 15/16" front bar and a 9/16" rear bar. Looking at the bars you can see that the big block has less understeer bias due to the greater front end mass, which naturally increases understeer.
F-41 (big blocks) involved the same substituition of parts as F-40 (small blocks) The difference is that the base big block suspension included a 9/16" rear bar, and this remained in place with F-41.
Duke- Top
Re: Sway Bars
DukeIn Appreciation of John Hinckley- Top
Re: Sway Bars
Yes, that is interesting. A dressed ZL-1 probably weighed about the same as the dressed base 350 - something on the order of 550 -600 pounds.
The '67 AMA spec list the "427 engine" option at 175 pounds, which is probably all on the front end.
Duke- Top
Re: Sway Bars
ALL the Corvettes were small block cars in 1975, so any rear sway bar set up after 74 production would have been on a small block car.
Lynn- Top
