62 Tie Rod Ends - NCRS Discussion Boards
62 Tie Rod Ends
  • Kenneth W.
    • June 30, 1996
    • 3
    62 Tie Rod Ends
    I'm looking for the part numbers for the front end Tie Rod for a 62.
  • Bob P.
    Infrequent User
    • 2
    Re: 62 Tie Rod Ends
    GM #s LH 3737595, RH 3737596
    • Donald L.
      • September 30, 1998
      • 461
      Re: 62 Tie Rod Ends
      Moog-ES-173R-Rt side
      ES-173L- Left side
      • William C.
        • May 31, 1975
        • 6037
        Re: 62 Tie Rod Ends
        If you are interested in accuracy for a restoration, remember that the grease fittings on the originals come in at an angle from the sides of the housing, most current replacements have the grease fitting on the bottom, incorrect for an accurate restoration. BTW, 54 and earlier chevy pass cars used the same parts.
        Bill Clupper #618
