My question is about snap rings that hold the yoke into the differential case. These snap rings have a rounded side and sharp/flat side. I looked in archives and found conflicting info about how they are installed.
Can someone explain the proper orientation when installing these rings. I had them rounded side inboard toward differential pinion gear pin but decided to turn them around.
One final question, are there thrust washers on differential pinion gears for non posi rear?
Thanks as always, Tim
