HVLP spray gun recommendations - NCRS Discussion Boards
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: HVLP spray gun recommendations
    You will not have to worry about VOC's much longer. Waterborn paint does not have that problem Your new cars are painted in waterborn, and it is filtering into the aftermarket
    Ahhhh...Ain't progress great!
    I can already hear the NCRS arguments about SS urethane vs BC/CC vs waterborne finishes. I'm expecting that, once waterborne finishes are forced on the aftermarket, the EPA will make VOC regs so stringent that even urethane will be emasculated as a durable finish (ala acrylic lacquer).
    But...as long as urethane can be found, the restoration wrangling will continue.
    • Jim D.
      • 2882
      Waterborne paint is applied as a base coat only. You still have to use a solvent borne clear over it.
      • Dick W.
        • 10483
        #18
        I was told at a paint seminar that clear is "right around the corner"
        Dick Whittington
        • Jim D.
          • 2882
          #19
          Learn something new everyday. I'm just glad I can buy and spray anything I want in Wa.
            Don't hold your breath - GM, Ford and Chrysler formed a joint program eight years ago with PPG, DuPont, and BASF to develop a non-VOC clearcoat material (powder, waterborne, or something not invented yet), and $800 million later, nothing has been found that works in a high-volume application environment.
            • Randy R.
              • March 1, 1983
              • 477
              #21
              Thank you for the replies. The Devilbiss Plus looks like a good choiceto me. Do I understand correctly that almost any cheap gun is suitable for primer? Any recommendations for a touch up gun?
              Rany
              • Joel F.
                • April 30, 2004
                • 659
                #22
                Rany
                That is correct Randy, any cheap gun can shoot primer good enough for our purposes. If it were me, I would not get a touch up gun unless you have a real need for it. For one or two paint jobs I think you will be fine without it.
                • Randy R.
                  • March 1, 1983
                  • 477
                  #23
                  Thank you,
                  I have a cheap gun for primer.
                  Randy
