Can this carb base plate be welded? - NCRS Discussion Boards
  • Mark P.
    • December 1, 2004
    • 62
    Attached is a photo of my 3814 broken base plate from my base engine car. Is it possible have this welded? If so, any recommendations as to who could perform this repair?
    Thanks----Mark
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Can this carb base plate be welded?
    "V" groove both side of the break and bolt the base plate with 4 bolts to a flat piece of steel and weld the top side. then weld the bottom side.
    • Mark P.
      • December 1, 2004
      • 62
      Clem
      I am encouraged that it is possible to weld. Do you or any other members know of a vendor or member who could perform this repair?
      Thanks in advance---Mark
        Originally posted by Mark Pate (42951)
        Clem
        Mark -
        Jerry MacNeish does them all the time - he's a wizard with Heliarc; he can take care of it for you:
        www.z28camaro.com, (410) 781-0418
        • Dennis C.
          • June 30, 2002
          • 884
          Another alternative is to find a local welding shop in your area that does Heliarc or Tig welding. Do the set up yourself as Clem described and have them weld it.
          Finding a local shop shouldn't be too dificult.
          Dennis
