54 Brake hoses - NCRS Discussion Boards
54 Brake hoses
  • Benjamin C.
    • July 31, 1994
    • 134
    54 Brake hoses
    Does anyone know of a supplier for smooth brake hose lines?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 54 Brake hoses
    nobody, to my knowledge, repos the smooth rubber tubing and the unique to original fittings found on original c-1 brake hoses. i searched ebay for a couple years to come up with three hoses for my recently restored 57. the NOS hoses scored well but i sure as hell won't have them on the vette when i PV the car in a couple weeks, after all, the rubber is damn near old as i am and not to be trusted(nor am i)mike
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 54 Brake hoses
      Buy the repro's and sand the lines off
      • Mike M.
        • May 31, 1974
        • 8365
        Re: 54 Brake hoses
        sanding the ribs off a repo won't get you the correct fitting that the steel tubing fitting threads into.mike
        • Roy B.
          • February 1, 1975
          • 7044
          Re: 54 Brake hoses
          Again mike is right ,but you have little choice
            Re: 54 Brake hoses
            Roy-----
            All of the currently available brake hoses I've seen use a slightly smaller OD hose than originals. It's not a huge difference, but it's rather easily discernable.
            • Mike M.
              • May 31, 1974
              • 8365
              Re: 54 Brake hoses
              joe is correct in that the OD of the repos is less than that of originals. however, its the inlet fitting of the repos that differs considrably from that of originals. the fitting of originals is one piece with a"flat washer' integral to the rest of the fitting. with the two piece repo fitting, the "flat washer" rotates on the main portion of the fitting. mike
              • Roy B.
                • February 1, 1975
                • 7044
                Re: 54 Brake hoses
                Talking about original parts under a Corvette what flight award has judges inspect under the Corvette.Are they looking at every part like the brake hose washers and more and so on Thanks
                • Mike M.
                  • May 31, 1974
                  • 8365
                  Re: 54 Brake hoses
                  roy: it appears you've never judged the chassis section during flight judging. i rarely leave the showfield without grass/blacktop/oil stains on my t-shirts after i've judged chassis.mike
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Re: 54 Brake hoses
                    I've done many engine areas ,interior and body fit . I do remember in 05 when my 55 was judged they hated to get under the vett because they knew I drive and came out saying %*&^# .
