66 BB Fuel Line - NCRS Discussion Boards
66 BB Fuel Line
  • William P.
    • August 31, 2003
    • 135
    66 BB Fuel Line
    Hi, I purchased a pump to carb line for my 66, 390 hp 427 and it is not even close . Has anyone had the same problem? I bought it from Corvette Central .The carb and the pump are correct .
    Regards Bill Purdy
    • 43193
    Re: 66 BB Fuel Line
    Regards Bill Purdy
    Bill------
    Where is the fitment problem; at the pump or at the carb?
    If the problem is at the pump, is the pump a type 40366 and does it use a brass elbow between the fuel line and the pump?
      • May 31, 1974
      • 8365
      Re: 66 BB Fuel Line
      if you have a 67 big block pump like Joe suggests, then you'll have to use a 67 BBC pump to carb fuel line. or you could buy the repo 66 BBC fuel pump from Paragon. its closely configured to an original 66 BBC pump but not perfect. mike
      • Steven S.
        • August 29, 2007
        • 571
        Re: 66 BB Fuel Line
        Long Island sells a replacement pump kit for '66 BB with an adapter fitting, not sure if they sell the fitting seperate, might be worth the call if that is your fitment issue.
        • Larry T.
          • May 15, 2007
          • 404
          Re: 66 BB Fuel Line
          I have a 66 BB and do not like the fit of my fuel line, from Corvette Central as well. I have a brass fitting on my fuel pump. It went on, but it was a bear.
          Is there supposed to be a brass fitting? I would like to see what the fuel pump should look like if anyone can post a picture.
          Thanks.
          • Steven S.
            • August 29, 2007
            • 571
            Re: 66 BB Fuel Line
            There is supposed to be a brass elbow for '66, the issue now is that the original '66 BB pumps had a pipe thread on the outlet, and the generic replacement pumps that are available all are theaded for a flare nut type connection (like '67 BB had originally). I believe you can use a '67 L88 carb to pump line (if you are working on a L72) with the replacement pumps to make it work, or come up with an adapter fitting and use the '66 line and elbow.
            • Michael G.
              • January 1, 1997
              • 1251
              Re: 66 BB Fuel Line
              Good day all. This connection should be close if not correct for the '66 427.
              • William P.
                • August 31, 2003
                • 135
                Re: 66 BB Fuel Line
                I have the brass fitting at the pump Joe, The line dosen't line up at the carb ( the angle is off a little and I think it is a little long here ) and it is about 1" too long at the pump end . I just got the pump with the brass fitting from Long Island Corvette .
                Bill Purdy
                • William P.
                  • August 31, 2003
                  • 135
                  Re: 66 BB Fuel Line
                  Hi Mike, Can you post a picture of the top across the manifold >
                  Regards Bill Purdy
                  • Michael G.
                    • January 1, 1997
                    • 1251
                    Re: 66 BB Fuel Line
                    Jus happen to have the engine sitting next to my computer.... Gas line may be the original however cannot validate. Engine details are not done however Bill you can get the gist.
                    • William P.
                      • August 31, 2003
                      • 135
                      Re: 66 BB Fuel Line
                      Thanks Mike , thats great!
                      Bill Purdy
