66 Posi Tag. - NCRS Discussion Boards
66 Posi Tag.
  • Ralph B.
    • July 30, 2008
    • 178
    66 Posi Tag.
    1966 JM specifies "USE POSITRACTION DIF. LUBRICANT 9985045"
    LIC list that for 1965's and for 66 " USE POSITRACTION DIF. LUBRICANT ONLY"
    Which is correct?
    Thank you,
    Ralph
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 66 Posi Tag.
    Ralph - My 1966 Corvette TIM&JG, Fourth Edition, Chassis Section 13. Rear Suspension, Differential and Yokes says the tag reads " USE POSITRACTION DIF. LUBRICANT ONLY". Pete
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: 66 Posi Tag.
      Pete --- here's a thought; last '65 has diff FA_7_15_65. Early 1966 VIN 00224 has the same stamped code.
      Here's my reading of the '65 AIM: the diff's arrived (on pallets ?) from Warren with the plug and (if posi) the tag in place. At St.Louis, they unscrewed the plug, added one of 2 kinds of bulk fluid (posi or not) and reinstalled the plug assembly.
      Always wondered if that #6S100224 might've had the same posi tag as 5S123564 (be it the '65 type [more likely] or the '66 revision). If yes, then it would certainly not be TFP for the model year(s), but explainable under EOP/SOP vagaries.
