My directional signals in the steering column do not move smoothly nor do they operate properly.
When I use the signal lever, it is stiff and will not return to center when the wheel is returned to center. I've lubricated everywhere.
Also, this malfunction affects the rear lights/brakes. Could the cable to the switch on the column be causing this? Also, I beleive I have the steering column "bar" lined up with the column itself by the "dimples".
Any suggestions?
Jerry
Any suggestions?
Jerry
