I have a 58 hand laid reproduction hood. It does not fit well on the back edge. At the back center, it has a height of 9/16 ". An original is approx 1/4". A potential remedy is to split the inner skin from the outer skin and rebond it correctly aligned to the cowl. The edges do not, however, have a clear demarcation between the skins. It appears to be a solid piece. Has anyone tackled this type of project? In other words, any suggestions for properly separating the skins without a visual border between them? Given that the edge appears to be a "solid piece", might another alternative be to merely sand the top down to specs? Thanks.
Tags: None
- Top
Re: 58 hand laid reproduction hood
Richard,
Are you saying that the fiberglass thickness is 5/16" more than it should be, or that there is a bow in the hood running from left to right resulting in the high spot?
I believe that even the hand laid hoods are made up of 2 pieces, top surface bonded to a separate frame.
In my opinion I don't think it's a good idea to grind down the top surface to solve the problem. You would loose the even surface and getting it to look right could be a time consuming task.
Was this a used hood or a new one from Ecklers? I ask because I'm waiting for a '59 hand laid nose and hood from Ecklers and concerned about having the same issue as yours.
Rich- Top
Assuming an original hood has a edge height of 1/4" in the middle of the back edge, mine is 9/16". This hood is more that 8 yrs. old.- Top
Before you start separating, grinding, etc., try the following:I have a 58 hand laid reproduction hood. It does not fit well on the back edge. At the back center, it has a height of 9/16 ". An original is approx 1/4". A potential remedy is to split the inner skin from the outer skin and rebond it correctly aligned to the cowl. The edges do not, however, have a clear demarcation between the skins. It appears to be a solid piece. Has anyone tackled this type of project? In other words, any suggestions for properly separating the skins without a visual border between them? Given that the edge appears to be a "solid piece", might another alternative be to merely sand the top down to specs? Thanks.
Support the hood on the outer edges leaving the middle suspended. Place weight on the trouble area, ( I used cinder blocks ) then apply heat from a heat gun to the bowed area. It will move! Take some measurements. Soak a towel with cold water and cool the area. You may have to do it several times to get it where you want.
I did this a few months ago on a '57 hood. The bow I had was worse than what you describe.
Good luck.- Top
- Top
Thanks. It would be nice if when restoring these cars everything would just "snap" into place. There seems to be a 1001 issues like this; doesn't make things easy.- Top
I know your pain. Read my recent thread about '63 vent window and door seals and channels. OMG I'm ready to have a migrane, pinched nerves, and a nervous breakdown!
- Top
