65 Rear emblem location coupe and convt - NCRS Discussion Boards
  • Jeffrey G.
    • June 30, 1986
    • 77
    Hi,
    Can someone verify if the rear deck emblem location on a 65' coupe is the same as a convt and the same from 64 and 65'?
    Even better, would anyone have a hole template they could share for this 65' coupe emblem? If yes, please email: jgoldacsind@yahoo or fax 401-6333-6088.
    I have measurements from a 64' convt, but want to be sure before drilling holes. I've found nothing in the AIM and due to prior damage don't trust the hole locations on the existing deck.
    Thank you, Jeff
  • Ed D.
    • December 1, 2003
    • 207
    Re: 65 Rear emblem location coupe and convt
    If you reach up under the bumper/ gas tank to the underneath of the fiberglass panel you will feel two slight indentations where the emblem mounting holes should be.
