JX / JY Shock Labels - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    After much confusion, it appears that JX and JY are correct labels for the 75 base option Shock Absorbers. Last dumb question...Which is front and which is rear?
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Jack H.
    • April 1, 1990
    • 9906
    Re: JX / JY Shock Labels
    This is nicely defined in your copy of the NCRS '75-77 Judging Guide. From the table in Section 12, Chassis: JX=rear and JY=front.
    • Alger R.
      • 279
      Thanks Jack. I knew it was a dumb question. I was at home last night and my Judging manual was at the shop. I should have waited but was anxious for an answer. You came thru as usual. I had correctly put the JY labels on the fronts but wasn't sure if maybe I should have used the JX for front. I attached a pic of the front shocks. Thanks, AL
      AL
      75 Convertible
      L48 M20
