Re: Speedo photos to Munie speedo post
OK Jack; now that the gear is off and the new one has arrived, time to do a little precision measuring. Frst, is there 8 teeth on both (ie. 8 locations around the circumference, where a tooth merges with the side) ?
Next, get out your dial or digital caliper and measure diameter and width. Width is easier (more accurate), except on that chewed-up specimen, could be a challenge.
For low numerical ratios (3.08, 3.36, 3.35, [and 3.70 if you use the silver 22-tooth gear]), #3708145; 1.765" dia, and 0.531" thick.
For 3.70 [with green 22-tooth] and 4.11's #3708144; 1.850" dia, 0.610" thk.
For 4.56 gears; # 3845079; 1.922" dia, 0.453" thk.
Let's hear what two you have.
