Question on transmission removal - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I would like to remove the engine from the frame. ( Body is off ) The question I have is.
    Can I leave the 4 speed transmission on the bell housing to save time on the re install ? I noticed two dowel pins to align bell housing.
    I want to take the engine in to a shop for a possible rebuild. rings valve job. Any help appreciated.
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: Question on transmission removal
    Wayne, yes, the bellhousing can be left in place.
    You may want to seperate them so you can remove and inspect the clutch fork.
      • 6940
      Wayne, I think that the engine re-install with the transmisson in place will make the alignment for a little more work , as you have the frame off, I would say remove as a assy. and re-install as a assy.
      • Wayne P.
        • January 23, 2008
        • 444
        think I posed my question wrong. I need to take the engine into a shop to have a look at it. I believe they require the transmission removed.
        Can I do this by just removing the bell housing with the transmission attached ? When I get the engine back I was thinking I could reattach
        the bell housing and place unit back in frame.
          • 6940
          Wayne, I say remove the engine, bell housing,transmisson as a assy. and re-install them as a assy. makes it a whole lot easier to just drop the assy onto the frame.once removed seperate the bell housing from engine.
          • Stephen L.
            • May 31, 1984
            • 3148
            Wayne, as said earlier, remove engine/transmission as an assy fro the frame. Separate the transmission from the bellhousing, (only 4 bolts) and the bellhousing from the engine. remove the clutch from the flywheel and inspect. Resurface flywheel????
            Get your engine work completed.
            Check the transmission for leaks on the front face; gear idler shaft sometimes leaks at the case opening. Replace seals at shift levers and output shaft.
            Reassemble clutch. Install bellhousing. Install transmission. Now you have a complete assembly to easily drop back onto the frame.
            Have fun.
            • Wayne P.
              • January 23, 2008
              • 444
              Thanks Stephen. all taken apart. Yes the trans was leaking at the front,
              Clutdh rusted and worn. another bill !!!! You got to love these cars.
