The subject has appeared before however the search has still left me without a decision.
Now my original drive shaft has a longitudinal line over the entire tube (Mar64)
So I must assume the tube was welded along that line.
Would that welding process leave approximately a 1/2" wide strip along the line of a black/blue tone?
Have a shop which suggested to retube my yokes to that type of material which they had in stock. Appears to be same diameter, but will check. Note; shop will balance it.
Now did the bluing from the yoke being welded show?
The yokes should look like a raw casting, correct? Anyone have picture of those subjects.
Do not think I want to retube mine since its original yet old, but not opposed to finding some yokes and having one made if the tube is correct.
