Is there a good, better, best way to adjust the carbs so as to get the quickest pop when cranking it over seems my center carb has no drip while front and back drip a little till started then I see drip at center, would like to get adjusted so it fires off after six or eight cranks instead of, well untill battery losses power, what is most of your 54s popping at, have adjusted floats several times and they seem fine, since I have taken choke mech. out and cleaned and lubed seems to just start way too late, kind of takes the fun out of climbing in and hittin the road. Thank, Brad
