When an item in the Assembly Manual is identified with a box (half black), instead of an Item Number, it means that the item is a part of the Engine Assembly? Does this mean that the item is painted orange along with everything else? If that's the case, would the EGR Valve Base (and parts of the Valve itself) and also the Air / Choke Manifold cover be painted orange? If not they must be assembled afterward but prior to assembly plant?
Thanks, AL
Thanks, AL
