1968 quadrajet question - NCRS Discussion Boards
  • Roald P.
    • February 20, 2009
    • 48
    Hello
    I have been trying to find out why my new "remanufactured" quadrajet causes my engine to 'knock' (68' 327 cui, auto)
    I think its lean, a buddy of mine tore it down and found the following:
    prim. jets .068
    rods .033
    idle tubes .038
    down ch. .052
    lower air bl. .060
    upper air bl. .090
    Sec. rods CH/.055
    POE well restr. .030
    POE restr. .040
    tube restr. .023
    M hanger
    the lower idle air bleeds: .062
    the upper idle air bleeds: .090
    main air bleeds in airhorn: .052
    main air bleeds in body: .114
    No APT system
    What shoud it be for a correct 1968 qjet specified for a 300 HP engine with auto and air?
    Roald
    • 6940
    Re: 1968 quadrajet question
    Roald, possiably a timing issue, advanced to far, maybe the check the vaccum advance operation,and the mechanical advance operation ,engine temp.- seem okay? a vaccum leak will lean out the mixture, but there should be a tell-tell sign, like the idle maybe rough.
    How does the car run and idle? other than the pinging.
    • Roald P.
      • February 20, 2009
      • 48
      it runs fine, idles good, no vacuum leaks, timing set very conservative at max total 30 degree's and vacuum advance disabled, still knock... I changed the carb to a Holley that was setup for a 350 cui and all pinging/knocks problems went away, but I would rather use the qjet for the original look
      • Clem Z.
        • January 1, 2006
        • 9427
        check to see if the EGR valve is working because with out the exhaust gas to cool the intake charge it will ping..
          • 15573
          Clem, Unless somkeone has made some changes there is no EGR on a 1968 -- thank goodness.
          • Clem Z.
            • January 1, 2006
            • 9427
            Originally posted by Roald Poulsen (50103)
            Hello
            prim. jets .068
            rods .033
            idle tubes .038
            down ch. .052
            lower air bl. .060
            upper air bl. .090
            Sec. rods CH/.055
            POE restr. .040
            tube restr. .023
            M hanger
            No APT system
            Roald
            the 68 327 corvette carb #7028208 should have #71 jet,#46 pri rod and a sec rod stamped "AN" with a .070 tip
              • 6940
              Roald, I find that the holley carbs are jetted quite differently, than the Q/jet, depending on the cfm.s of your holley, and the Q/jet may indeed make the difference of a slightly richer mixture with the holley.is the Q-jet carb. a factory carb, for you 68/300 engine?
              I dont have any spec.s on the metering of you carb. but there is one member that posts quite often. with spec. on the carbs.as I have rebuild many carbs in my day, from dealership experience. if all the internal spec.s are on such as the float level, metering rods, jetting is the only other thing.
              • Roald P.
                • February 20, 2009
                • 48
                the holley was a 670 street avenger and an old 600 cfm spread bore holley. I tested two holley carbs both worked without knocking and the engine had more power with them.
                no, the qjet is a rebuilt from zip corvette - the original is unfortunately long gone
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Roald since 1974 I have been using a Holley 6210 650 spreadbore double pumper on my original owner 68. Just recently put a Holley renew kit in it. I like the positve control of the secondarys with this carb. Best change I have ever made to the car. Great performance on the original L79 327/350HP with M21 and 3:70 rear.
                    • 6940
                    Roald, sometimes carb.s out of the box are a hit or miss. one carb. number may fit a dozen or more applications. as Clem posted the metering rod sizes to be different than what you posted. there are many good quality rebuilders in the driveline or maybe some of the TSB members know. and in general, they know all the tricks of the metering needed for todays gasoline formulas.
                    • Roald P.
                      • February 20, 2009
                      • 48
                      • Paul H.
                        • September 30, 2000
                        • 678
                        Did the same with my otherwise stock 68 427/390. Felt like I bolted on 100 horsepower. Great throttle response and great low and mid-range torque. I know many swear by the Q-Jet but there are very few people out there who rebuild them properly.
