66 bb rear leaf spring - NCRS Discussion Boards
  • Bill H.
    • November 15, 2007
    • 54
    What would be the more correct rear leaf spring for a 66 bb 427/390 ?
    It should be a 9 leaf spring but which one?
    One version of the 9 leaf spring has all 9 leafs curved and touching, The other version of the 9 leaf spring the 6 longest leaves were curved and the 3 short ones were straight. This spring is know in the spring world as a 6/3 spring and/or a two stage spring (aka variable rate).
    Eaton offers both any suggestions?
    I have a replacement spring without turned up ends so I'm not sure what was there originally.
    thanks
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 66 bb rear leaf spring
    Small and big block engines used the same spring. 6 arched leaves and 3 straight.....aka variable rate spring. Spring you have indicates a replacement spring.
    • David L.
      • July 31, 1980
      • 3310
      The 1966 Corvette Specifications (dated September 1965) by the Chevrolet Engineering Center, Warren, Michigan, describes the rear spring as follows:
      Type: Multi-leaf, 9 leaves
      Material: Chrome carbon steel, heat treated
      Length (developed) between eye centers: 46.36
      Width: 2.25
      Design load, lb @ - camber: 1360 @ .352
      Defelection rate, lb per inch, @ design load
      @ Spring: 140
      @ Wheel (wheel rate): 123
      Spring liners
      Number: 7
      Material: Polyethylene with graphite
      • Bill H.
        • November 15, 2007
        • 54
        ordered the 6/3 from eaton today
        meets the specs above
        thanks for your help
        • Michael F.
          • 745
          let us know how you like the eaton spring
          Michael
          70 Mulsanne Blue LT-1
          03 Electron Blue Z06
