I reviewed the archives and have painted the center grill so i know I have the right paint. Used original dupont formula as posted in archives.
Question is regarding the chrome not painted.
Should the front edge of the chrome along the very bottom (chrome area where studs are on the back) and up the side get painted or just the top side. This would be the short vertical surface as you look straight at the grills. Exactly what chrome surface on the egg crate section is showing. Mine were original and it looks like just the chrome vertical and horizontal edges were fully exposed. Is that correct or should any of the flat surfaces inside the squares of the grill have chrome exposed as well? There appears to be light over-spray on all inside surfaces of the squares.
I hope I am explaining this correctly. Does someone have good close up pictures?
Bill
Bill
