Guage Face (back side) - NCRS Discussion Boards
  • Jim K.
    • August 31, 2000
    • 554
    Had the speedo fixed (Thanks JR) and decided to paint and clean it all up. Got some new lense gaskets and turn signal lenses. Putting it back togethre, there are two small strips of rubber that go over and under the trip counter and:
    1.) I don't seem to remember what goes between them and the guage lens retainer... I know the back side of the retainer gets the foam gasket then the speedo.
    2.) do the turn signal lenses fit right in or are they supposed to be a tight fit? Assume dull side out is right.
  • Jim K.
    • August 31, 2000
    • 554
    Re: Guage Face (back side)
    I figured it out, it was the plasstic lense for the trip... duh!
    Now I just have to figure out what the capacitors connect to...
      Jim -
      The one adjacent to the ignition switch connects to the brown wire from the harness, the one near the tach with the ScotchLok connector attaches to the tan wire going to the "Brake" warning light bulb socket, and the one near the battery gauge goes on the outboard spade connector.
