R43XLS spark plugs the way to go on an l36 or no? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Since I'm buying new plug wires that are dated coded for me 68 are the R43XLS a good choice for a stock rebuilt l36?
    btw I'm ordered 3-Q-67 dated plug wires I think that is what I need for my 68 which was is build dated nov. 7th 1967 correct?
    one other thing braided wires on ebay are like $97 and on paragon for $130 but the ebay ones don't mention being date coded. Where are they date coded at? hate to throw 30 bucks away on something you can't read when the wires are installed...anywhere cheaper that sells the dated ones?
    thanks for any help.
  • Ralph P.
    • February 1, 1990
    • 253
    Re: R43XLS spark plugs the way to go on an l36 or no?
    Brandon, look in archives.... I think you'll find that 45's are the recommended range for "normal" driving . 43's are too cold & prone to foul....
    • Dick W.
      • 10483
      If the car is going to be a trailer queen show car install the dated wires. If you plan to drive it and want it to run halfway decent, buy you a good set of wires, made by MSD or other performace manufacturers. The repro wires are pretty much crap as far as driving
      Dick Whittington
      • Brandon T.
        • October 23, 2008
        • 872
        thanks, what is the exact model of the plug you're referring to?
        just R45XLS? or what?
        thanks!
        • Ralph P.
          • February 1, 1990
          • 253
          R45XLS is the AC Delco number.
          • Brandon T.
            • October 23, 2008
            • 872
            thanks, I'll go with those but having a problem finding them advance etc don't seem to carry them on their sites.
            have they been discontinued?
            • Ralph P.
              • February 1, 1990
              • 253
              You may have to look up a local AC Delco distributor......they should be easily available ... not discontinued .
              • Brandon T.
                • October 23, 2008
                • 872
                BINGO!
                this it? http://www.summitracing.com/parts/AC...s/?prefilter=1
                if thats the exact plug you are talking about I'll get some on the way.
                says the only chevy it's recommended for is an chevy luv 4cly truck haha.
                • Jean C.
                  • June 30, 2003
                  • 688
                  Brandon,
                  Ditto Dickie on the wires. I find that if my local NAPA store does not have the plugs I want in stock, they can order and receive AC Delco plugs the next day.
                  Best regards,
                  • Ralph P.
                    • February 1, 1990
                    • 253
                    Looks like the ones you need ..( Be sure they come with the top connectors & washers ) . Check gap per your manual ... probably .035 .
                    • Brandon T.
                      • October 23, 2008
                      • 872
                      Sorry, but what do you mean by top connector and washers?
                      never had anything but the plug itself when I've changed plugs.
                      • Ralph P.
                        • February 1, 1990
                        • 253
                        Just that the Summit picture shows a plug without the top connector . I just looked a an old R45XLS & it does not have a screw-off top connector . So, maby their example is for marine -use ? Anyway, I'm sure if you just specify the above number, it should come with everything you need for an automotive installation....including a new washer ( don't reuse the old one ).
                        • Nick L.
                          • May 31, 1998
                          • 82
                          I cannot see much difference, if any in the R44XLS and R45XLS in street driving in my 67 L-68. I agree the R43XLS is too cold.
                          Even NAPA does not stock the above anymore. They look at my like I am mad when I order 4 sets at a time. I tried to buy a tuning kit with distributor springs and weights and he had to go get one of the "old" guys becaues he had absolutely no idea what I was talking about.
