63 starter issue - NCRS Discussion Boards
63 starter issue
  • Michael G.
    • November 12, 2008
    • 2155
    Re: 63 starter issue
    Michael,
    Here's a close-up of the gear teeth. Let me know what you think.
    Thanks, Mike
      • 43193
      Originally posted by Michael Garver (49693)
      Michael,
      Thanks, Mike
      Mike-----
      This starter drive looks to be brand new and correctly configured. Attached are photos of an NOS GM starter drive. This particular one is about 45 years old.
      • Edward J.
        • September 15, 2008
        • 6940
        Joe, would and 153/168 flywheel require two different starters, so if a 67 flywheel and starter is used with the 63 starter, may it not be a miss/ match. the reason I say this is because a frenid has a 63 that had a turbo 350 trans. installed and we re-installed a p/g and had the reuse the same flywheel and starter(168 tooth) and the dust shield. HMMM-what do you think.
        • Michael G.
          • November 12, 2008
          • 2155
          Looking at your gear, my old one, and another new one I found, the difference in the gear is slight, but there is a difference. A close look at the pic I posted shows that there is a witness mark where the ring gear made contact with each gear on the drive. Notice that this mark is on a flat portion of the drive gear end, before the radius found on the end of each tooth starts. As Michael noted, my gear seems to have less radius, and more flat, than the others, so, my guess is that the same starter position would not lead to the gear "camming" into place.
          It would appear that the "cam" action that is supposed to happen when the ring tooth gear contacts the radius would happen if I added a shim or two. I just got some shims (after going to four auto parts stores, they are hard to find) so I'll measure how far the tooth needs to move and shim it that much. Wish me luck.
          Mike
            • 43193
            Edward------
            The only significant difference between a starter designed for a 153 tooth flywheel and a 168 tooth flywheel is the starter nose. The starters may also be "high torque" or "standard torque", but that does not relate to flywheel applicability.
            Starters for 153 tooth flywheels or flexplates ALL use an aluminum nose with "straight across", "long bolt-short bolt" mounting.
            Starters for 1963+ 168 tooth flywheel (note: no Corvette used such a flywheel or flexplate for 1963-65) AND manual transmission, used a cast iron starter nose with "offset" bolt mounting pattern and "intermediate length" mounting bolts. This starter nose was also used for 1968-69 Corvette with THM-400.
            Starters for 1970+ with 168 tooth flexplate and auto transmission used a starter with aluminum nose, "offset" and "2 long" mounting bolt configuration.
            • Michael G.
              • November 12, 2008
              • 2155
              Just for kicks, before trying a shim, I threw in another rebuilt starter. The nose and gear of the second rebuilt one looks pretty much identical to my original 67 one. The car turned over with no problem.
              I may ask the vendor who rebuilt my correctly dated one to change the gear to something that looks more like the others, or, I my put the nose of the new rebuilt one on the dated body myself, rather than shimming it.
              Mike
              • Joe R.
                • July 31, 1976
                • 4547
                Mike,
                Go and purchase the shims like was suggested and you will see how and why to shim the starter.
                Starters were machined differently as well as blocks so every starter does not fit every block.
                Yes, I know it's hard for some to believe that blocks and starters are not perfectly machined every time.
                That's why God invented shims.
                JR
                  • 43193
                  Mike
                  Mike------
                  If I were going to do this myself, I think I'd transfer just the nose and drive from the second rebuilt starter to the correct one. That way, you keep all the "rebuilt" elements and the correctly numbered frame. This is an easy swap-out, too.
                  Make sure there is a new bushing in the nose you transfer.
                  • Michael G.
                    • November 12, 2008
                    • 2155
                    #24
                    Mike
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      #25
                      Mike
                      Mike, just curious. How did the starter episode turn out?
                      • Michael G.
                        • November 12, 2008
                        • 2155
                        #26
                        Michael,
                        I'm not having the best luck. After I installed the the second, non-matching, starer, I started the car with it just fine, without shimming. Unfortunately, about thirty seconds later I broke #5 intake push rod , so I'm sorta preoccupied with that, as a starter isn't necessary on an engine that can't seem to keep its valve train together for more than a few minutes of run time.
                        I think I'm gonna ship the starter back and ask them to put on a more typically profiled drive gear.
                        As for this engine, I think the cash-for-clunkers Obama solution might be in order here. I'll let you know what happens.
                        Thanks, Mike
                        • Timothy B.
                          • April 30, 1983
                          • 5177
                          #27
                          Michael,
                          Let me know if you decide to go with cash for clunkers, I may be able to do a little better than that..
                          Keep the Faith..
                          • Michael G.
                            • November 12, 2008
                            • 2155
                            #28
                            My new ZR1 is in storage 'til the snow goes away, so maybe I'll just "borrow" the LS9 for a while for the 63. That'd cheer me up.
                            Mike
