Door Panels/1970 - NCRS Discussion Boards
Door Panels/1970
  • Roger M.
    • December 9, 2009
    • 2
    Door Panels/1970
    How do I secure/install window crank spacer on new door panel on 1970 vette/al knoch interiors ? Thanks
  • D S.
    • March 1, 2005
    • 1551
    Re: Door Panels/1970
    Roger, the window crank spacers are supposed to have three or four (can't recall which) metal tangs that bend outward to secure them after the tangs pass through the holes to the inside of the panels.
    • Warren F.
      • December 1, 1987
      • 1516
      Roger,
      If I'm understanding you correctly, after fastening the door panel in place, place the window crank spacer onto the splined shaft sticking out of the door panel opening. Take your window crank handle and place the retaining clip into the grooved ring of the backside and press the handle onto the spline and push. It should secure in place with the window crank spacer against the door panel and the window crank handle against the other side of the spacer.
