Looking for good clear photos of 1972 LT1 engine stamps for research project.
1972 LT1 engine pads
Re: 1972 LT1 engine pads
I may have yours. What's the four digits of the VIN?
MarkKramden- Top
0942, I hope you are a better camera man than I am! I can't get a good shot of it!There are just to many things in the way to get a good picture?
I didn't see you snap any pictures, the car has only been out in public once?
Kevin- Top
My little contribution to this interesting tread. Same one, different focus...I wish I had a few different ones but it's my 1st LT-1...
Marc1972 LT-1
2011 GS- Top
I've been collecting engine pad stampings for sometime in my research on '71 LS6 Corvettes. However seeing some examples of the small block stampings for the LT-1 engines is interesting. The first feature I noticed is the two different numeral zero's used in the engine assembly stampings. It also appears that the numeral 6 or 9 looks identical, as if it can be used interchangeably.- Top
I've been collecting engine pad stampings for sometime in my research on '71 LS6 Corvettes. However seeing some examples of the small block stampings for the LT-1 engines is interesting. The first feature I noticed is the two different numeral zero's used in the engine assembly stampings. It also appears that the numeral 6 or 9 looks identical, as if it can be used interchangeably.Dick Whittington- Top
