I have a 78 Pace Car with 1300 miles on it. It's an L48 with a 4 speed. When I bought the car last summer with 1100 miles on it the transmission worked fine. However, last fall before I put the car away for the winter it developed a shifting problem. The transmission works fine when upshifting in all gears, however, when downshifting from 3rd to 2nd or 2nd to 1st the gears will grind if I try to downshift.
Also, when the car is in 2nd gear and and I rev up the engine (to around 3000 rpms) the shifter vibrates badly. If I disengage the clutch and let the car coast the vibration goes away completely.
Here's what I've done so far:
- changed the transmission fluid
- checked the clutch free pedal travel
- checked the clutch spin down time and it's OK
My questions are:
1 - could this be caused by misaligned linkage?
2 - are there any other adjustments that I'm missing that I could check?
3 - at the Marlborough regional last year I got a Bowtie signoff on the car so I'm planning to bring it to Charlotte in July for Bowtie judging. Assuming that the transmission needs some internal work that will require it to be removed from the car would I be better off leaving it alone until after it's judged in Charlotte? I don't plan to drive it until I get this problem fixed.
Any help is greatly appreciated.
My questions are:
