1956 distributor differences - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1916
    Can anyone tell me what the difference(s) are between the 1110872 and 1110879 distributors?
    Many years ago someone (I can't recall who) told me that he had all of the original blueprints for the early distributors. Anybody know who that might be?
  • William C.
    • May 31, 1975
    • 6037
    Re: 1956 distributor differences
    There is a small difference in the advance curves, as follows:
    1110872 0-4@700, 15-19@1500, 20-24@2400, 26-30@3500, engine rpm and crank timing.
    1110879 1-5@800, 12-16@1500, 19-23@2600, 26-30@3700
    Bill Clupper #618
    • Edward M.
      • November 1, 1985
      • 1916
      Bill;
      What can you tell me about external physical differences. I am specifically interested in differences in the oiling tube between the two distributors? Is there a difference?
      • William C.
        • May 31, 1975
        • 6037
        Sorry Ed, I've got the parts lists for Generators, but not for Distributors except the vacuum units. FYI, the March '57 Parts book calls for the 1935509 oiler assy for the 1110879, and shows that for all '56 apps.
        Bill Clupper #618
        • Edward M.
          • November 1, 1985
          • 1916
          Yeah, I saw the same thing. I am wondering if there is actually a different part number for the oiling tube that went on the 1110872 distributors.
          Don't know why there would be, but then again, I don;t know why my 872 has an oiling tube that is 180 degrees different than the ones on the 879 distributors.
          Anybody got an unrestored 872 distributor with the original oiling tube on it?
          • Paul B.
            Infrequent User
            • August 31, 1989
            • 4
            The '872' Distributor used an oiling tube that came straight up 90' whereas ALL '879' and '891' Dual Point Distributors used an oiling tube that had a second 90' bend that moved the top of the oiling tube ~45' CCW as viewed from the top. Apparently the engineers found out that it was impossible to lubricate the '872' without this ~45' assistance. I have examples of BOTH style in my 'archives', Paul
            • Edward M.
              • November 1, 1985
              • 1916
              Paul;
              The oiling tube on my 872 doesn't do either. My oiling tube has a second 90 degree bend tat moves the top of the ouling tube ~45 degrees CLOCKWISE as viewed from the top.
              • Paul B.
                Infrequent User
                • August 31, 1989
                • 4
                I did see a 1956 Dual Point Distributor @ The Bloomington Show ~5-7 years ago that had what you are describing which 'could' have been an early '872' also. The opposite ~45' clocking would have made it impossible to lubricate the tube without removing ALL of the shielding??
                • Edward M.
                  • November 1, 1985
                  • 1916
                  Yes, but I believe that it would be original for 872s. At least that is my thinking.
                  My 872 is dated March 5, 1956 (C 5 6) and is the original distributor for VIN 2117, estimated production date of April 24th, 56.
                  According to the data I have, there were 2218 872s made for production, plus 4 for service. The changeover to the 879 seems to have occurred around mid May, so my 872 could be considered a late production 872.
                  Do you know of 872s with oiling tubes other than the one I described?
                  • Edward M.
                    • November 1, 1985
                    • 1916
                    A picture (or four) is worth 1000 words. The distributor must be installed with this orientation to provide proper oiling to the heads.
                    Oil tube curves clockwise around the distributor. 879s and 891s oil tube curves counter clockwise around the distributor.
                    Numbers are hard to read, but they are 1110872 6 C 5.
                    Oil tube is almost directly opposite the tag on the distributor.
                    • John N.
                      • February 1, 1975
                      • 451
                      The 872 was also used on the 1956 Pass car, maybe they were fazed out of Corvette production earlier. I have a very early 872 and the tube is straight up.
                      Regards
                      • Edward M.
                        • November 1, 1985
                        • 1916
                        OK, so it seems like John and Paul have (or have seen) 872 distributors with oiling tubes that come straight up.
                        I have an 872 with an oiling tube that curves clockwise behind the distributor.
                        I am wondering if early 872s had the oiling tube straight up, then a change was made to get the oiling tube out from under the ignition shielding. Perhaps the first attempt at this (curving behind the distributor) had some problems.
                        Anyone else out there with an original 872 distributor?
