I bought one of the pressurized tank type media blasters from Harbor Freight. It is the tank type that you see on ebay and elsewhere. They all look very much alike. I bought it to blast small metal parts, i.e. remove paint and rust. When it works correctly, it is great at cutting down to the bare metal.
I can't get it to work reliably. Is there anyone out there that has gotten these to work. Here is what is happening:
I am using 70 grit aluminum oxide media and the blaster is set to 90 pounds. When I open all the valves and then the the nozzle valve, I sometimes get a large amount of the media blowing out which doesn't do any cutting. If it does blast correctly, it cuts great, but only blows the media for a second or so then just air, then I have to manually shake the tank, then it will blast with media for a second or so, the I have to shake it again.
Help!!!
Don Harris
Help!!!
Don Harris
It seems like it would depend on the velocity in the header, and the amount of slope...if the header is properly sized, the flow velocity should be less than about 5-8 fps to minimize pressure losses and provide slower flow to maximize cooling and condensation. I'm not sure the heavier condensate would be blown uphill at those velocities, but what do I know.
