68 Radiator Support Harness/Hose Grommet Question - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    I have what I beleve is an be an original harness/hose grommet for a 68. I just don't remember what size the opening is that it fits into. This measures 15/16" across the opening. I was wondering if someone could measure the opening in ther support or if they knew for certin off hand what it was. For some reason I think that the opening is larger.
    Thanks in advance,
    Rich
  • John C.
    • January 1, 2005
    • 616
    Re: 68 Radiator Support Harness/Hose Grommet Question
    Rich
    The rough inside dia on the grommet on my 68 is 1-3/8th. I can't measure the actual core support hole with the gromment in place but in the K66 section of the AIM the hole is called out as being 1-33/64 dia.
    John
    • Terry B.
      • August 31, 1999
      • 607
      Rich,
      Your dimension on the pictured grommet sounds small. I don't think the headlight connectors would pass through a 15/16" opening.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
      • Jack C.
        • September 30, 1992
        • 1090
        Rich, the 1 3/8 looks correct. On mine the TI harness goes through the bottom hole with grommet and the headlight and vacuum lines go through the top whole with grommet. When it warms up I can give you an exact measurement.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Rich P.
          • January 12, 2009
          • 1361
          Thanks Guys,
          I thought it looked too small.
          Rich
