63 Convertible
License plate light has single male connection for power and the ground is secured to the light assembly; correct? With wires (and alligator clips) directly from the battery, positive clipped to the wire lead, negative clipped to the corner of the assembly (where the harness ground would be secured), but no light. Ground clip is to bright, clean metal.
Background: when I first tested the light in this manner, it was successful. Afterwards, I taped the light socket and sprayed on a thin coat of paint. The next test did not work. There was no paint in or on the socket. I stripped off the paint. With a dremmel tool, I cleaned the socket to bright metal (inside and out) and also cleaned the corner for the ground to bright metal. If I apply the ground directly to the base of the bulb or the socket, the bulb will light, but not with the ground to the corner of the assembly.
